XP not allowing FoxPro to start up after sbowing the application's splash screen
Error loading stylesheet: An unknown error has occurred (805303f4)http://www.reimageplus.com/xml-report/report.xsl
Cleaning up instance tags for file 0x16e76.
Cleaning up minor inconsistencies on the drive.
Cleaning up 9741 unused index entries from index $SII of file 0x9.
Cleaning up 9741 unused index entries from index $SDH of file 0x9.
Cleaning up 9741 unused security descriptors.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Windows has made corrections to the file system.
0 KB in bad sectors.
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
Access is denied. Error processing resource 'http://www.reimageplus.com/xml-report/report.xsl'.
where did the image program get the files to replace??
are you still using internet explorer??
and if the reimage program has repaired files then is the foxpro program working now?/
