okay, will give it a shot.
For Twitter videos and all check H.264, install manualy LAVFilters 0.70.2 (no other) x86 from https://github.com/Nevcairiel/LAVFilters/releases
Only install_splitter.bat
Preferences, Content, uncheck Use MSE asyncro..., mark everyone else https://www.youtube.com/html5 All blue
Mypal add-ons: http://addons.palemoon.org/extensionsYour welcome.Well i was searching for uBlock origin for firefox 27 because mozilla said that im running firefox 27 on My Pal
.So i always search for addons like "Noscript for firefox 27" and i find them
Delete the folders:Its all red here. I don't even have a plugins page, it just says no plugins and 5 out 6 features are red.
the github forum might cover some of them as well, but I now have all I need,![]()
The adblock is not the bestMypal add-on: http://addons.palemoon.org/extensions
It may be, but it is customary and I use custom filters. I do not know if I can transfer custom filters from Adblock Plus (FireFox) or Adblock Latitude (Mypal) to other add-ons.The adblock is not the best
In my opinion ublock origin is the best adblockerIt may be, but it is customary and I use custom filters. I do not know if I can transfer custom filters from Adblock Plus (FireFox) or Adblock Latitude (Mypal) to other add-ons.
You have no plugins install flashWhy does it install profiles in two different places ? There is one in application data and one in local settings/application data
In your initial post you say that you have copied profiles. You must have damaged something that has been recorded in the windows registry.Same result. I cleaned everything out, user files, profiles, palemoon etc. and re installed 27.9.4 again.
