I have already created the PEbuilder disk. In addition to the PEbuilder, do I also need AMLNK.ISO?If you haven't done so already Janice, you need to create or D/L the "AMLNX.ISO" file to boot with.... otherwise you would need to re-install Windows and then the BackUpper program to do a restoration.
Looking forward to reading your report on this. :bI'm currently testing Macrium Reflect 7. Users rave about it on a Windows 7 forum I'm on. It is free for home users, is XP compatible and has many of the same features available in Acronis True Image (Full backup, incremental, differential, backup to image, clone drive, restore, create rescue media, etc.)
When my testing is completed I will create a guide here on backing up and restoring XP with Macrium.
You shouldn't also need the LNX file Janice..... so long as you have already tested booting with the disk you created and can access the IMG file. :bI have already created the PEbuilder disk. In addition to the PEbuilder, do I also need AMLNK.ISO?
Try SUPERAntiSpyware Free. It works fine on my XP 64So far, Malwarebytes is a flop.
Perhaps XP Pro x64 isn't all it's cracked up to be?
You are more fortunate than I was..... I gave XPpro64 a month, and it was a month of numerous problems. I since replaced that OS with the 32 bit version and it was like night and day. Thanks just the same... :bXP 64 works great for me with an Intel I7-2600 8gb ram. I've been running it for years.
SUPERAntiSpyware free version is better than Malwarebytes. It works fine on XP64.
2nd HDD arrived for this laptop. It is identical to the current drive installed.
Now, I've built systems in the past. Desk top and tower cases. I've replaced major components including MB's, Power supplies, and drives.... including the easy plugin stuff. But I've never wrenched on a laptop.
I am curious, how many here occaisionally or regularly clone or image their os hdds?
I couldn't find any documentation on adding a secondary hard drive but it appears there should be a caddy in the same slot as the primary hard drive that will accept the additional hard drive. If the caddy is missing you will have to order one.
https://www.dell.com/support/home/us/en/04/product-support/product/precision-m6400/docs
does none of the documentation here show you how to do this?
