Maybe this site problem then, because I also block cloudflare.
Yes visibly twitter solved this DCBrowser problem, I think..Maybe this site problem then, because I also block cloudflare.
So in the sense that an "IE shell" is just a "front end GUI" for IE's rendering engine, I basically went from Sleipnir to GreenBrowser to Official Pale Moon to Roytam1's New Moon 27 to Roytam1's Arctic Fox to Roytam1's New Moon 28.
I was using Roytam's Arctic Fox when I joined MSFN (thus the lack of originality in my username and little expectations of being at MSFN anywhere near as long as I have).
I was using the Firefox rendering engine without using the Firefox GUI.
I always liked my web browser to be "light and efficient".
Agreed 100%Arctic Foxie,
awesome todo list.
Test it.I've been using the regular 13.5.1030 version for awhile now and it works very well.Only issue is sound breaking up on videos,but it doesn't happen all the time.
I think I read that the sound problem has been a Chrome problem for years.
Would the regular 13.5.2022 version be a significant improvement over regular 13.5.1030 or not so much?
Try his V13.0.2170.0 with the updated files accept for chrome.dll and tell us if your videos skip anywhere near at must. Even @NHTPG may revert it at some point as they both use the same chrome engine but the application is heavier.I've been using the regular 13.5.1030 version for awhile now and it works very well.Only issue is sound breaking up on videos,but it doesn't happen all the time.
Thank you for your efforts, @ArcticFoxie !Here are download links for 13.5 build 1030.
Should prove to be much more RAM-friendly.
RAM used here NOW (with rebased chrome.dll): =79 MB only for 360Chrome 13.5.1030 r7regThank you for your efforts, @ArcticFoxie !![]()
