there is a problem
when you say loading user settings, what screen is this?
Does not matter what the files are if they are in tmp folders or have .tmp file extension they can be deleted, sometimes an antivirus will have an undeletable temp file, but that is the only one I know of.
what do you have starting up on your pc?
go to start/ run/ type in msconfig / then choose startup tab, what is listed?
