good day! Anybody knows good anti-ads to Serpent? Where i may download it?
wow, its worked good! thank you.uBlock Origin
Попробуй здесь:a good current link
its other questioncorrect method to import all settings, bookmarks, etc
You will need 7Zip to extract files from a .7z archive file. D/L the program from here:If you or anyone could give me instructions for installing this, I'd really appreciate it.
https://www.7-zip.org/download.html
Extract Basilisk files into a separate directory. With Basilisk55 the contents should be 87 files / 10 folders. There is no setup program.... it's a stand alone browser.
Run Basilisk.exe
Good Day,
Wolf
Yes, my previous test result was from Firefox version 52.90. I thought your previous message meant Firefox.
Just now I tested it on Serpent 2019.10.25 and whatismybrowser does show as Windows 10 but that firefox addon link does complain it as 52.90 (I think it depends on which addon?). I use Serpent, mypal and Firefox frequently. However, I didn't use the firefox addons for Serpent so didn't know about the problem. I use the addons from palemoon or
https://addons.basilisk-browser.org/addon/adblock-latitude/
However, when I visited
https://addons.mozilla.org/en-GB/firefox/addon/adblock-plus/
It didn't complain it wasn't Windows 10
Can you try the above link ? If you still have whatismybrowser as 52.90, maybe worth you checking if there is any typo in about:config I mean the useragent.
PS I use Serpent because it's the only one that can play the video clips at the BBC site. I still have no idea why.
Yes, this is true.Not my expertise, But RoyTam1 Serpent/basilisk 52 is a higher FF build than RoyTam1 Serpent 55. Am I getting that right???
Hello and nice day all
This also happens with McAfee and Norton - they (both) treat that shortcut and executable as infected and try to delete, this was also happening to new moon but its been quite some time since I've even used that browser that I can't recall. Like Elizabeth wrote: we need to find a way to put it on the safe list or configure our security scanner(s) to avoid the directory and shortcuts (I like to have custom shortcuts that would seem odd to scanners). For the record, this doesn't happen with any of the malwarebytes security software I use (Malwarebytes Anti-Malware / Malwarebytes ADWCleaner V 6.0.4.7 / Malwarebytes Anti-Rootkit)
That being said, I think that fact that some security software detects something (could be) wrong with those shortcuts does mean their doing their job, jut a bit overzealous in their detection.
I'm currently on:Just so you know, my Mypal (spoofed as Win10, FF69) plays the BBC videos.
Ugh ... that day has come a tad early and I'm finding this to work better.I'm currently on:
Version 52.9.0 (32-bit)
Build ID 20220617032904
I find:
user_pref("general.oscpu.override", "Windows NT 10.0");
user_pref("general.useragent.compatMode.version", "91");
user_pref("general.useragent.override", "Mozilla/5.0 (Windows NT 10.0; Win32; x86; rv:91.0) Gecko/20100101 Firefox/91.0");
...will play just about everything without any issues
