I have not heard of the link u gave but I am downloading the pack to see if it is better than wsus.
have to try to translate the screenshots.
have to try to translate the screenshots.![]()
DE051; Dimension - 2400C, 3000, 4600, 4600C, OptiPlex - 170L, GX270 / GX270N, SX270 / SX270N
do the following please:
msinfo32
Click OK, and when the System Summary info appears, go to the left hand pane and select components, choose modem, once the info appears, thenclick Edit, Select All (Ctrl-A), Copy (Ctrl-C) and then paste (Ctrl-V) the information back here in your next reply.
when I highlight this in my system summary I get a blank page.
you can make your own iso, with imgburn
http://www.imgburn.com/
good luck with future work, if you have more questions, start another thread.![]()
I could use a downloadable resource CD as well. So the question is, CAN Dell provide me a downloadable resource CD from the internet or WILL they not?
* Everything on the Resource CD (including diagnostics) is available for download . There isn't a single zip file that holds everything the original Resource CD held.
