XP Pro 32 Bit Drive Expansion
I have a dilemma. I'm using a Windows XP Pro x86 VM hosted on Windows 10 Pro x64 using Oracle VirtualBox. In the VM, my C drive is sitting at 10 GB. I was able to add a blank partition in of almost 100 more GB, but I can't find any way to extend the C drive as I would normally do.
See Picture
photo.php
I think when you created the VM of XP you may of used the fixed size option now it stuck at 10GB
