I can give you instructions for Hiren's boot disk but it is not an OS it is a tool, generally used to fix xp when you cannot boot to your OS.
Courtesy of Jose Ibarra:
http://www.hirensbootcd.org/download/ (look near the bottom of the page, do not click on any ads).
http://www.hirensbootcd.org/burning/
Instructions
http://rufus.akeo.ie/
