My Brother MFC-465CN printer from 2008 which has always worked great threw a "unable to clean 46" error code.(ink absorber pad is full)
Found a easy fix that many say cleared the error code and they could print again.
When I tried the procedure to get the printer into maintenance mode it will not stay in maintenance mode.
It will say maintenance on the screen briefly then switch and say something else every time I try.
Brother support say's it's a hardware failure-not sure if they are telling the truth.
Are there any XP 32 bit compatible printers available?
I need a USB connection-no wireless.
Just need a basic low cost printer as I don't print a lot.
