win32 please help
Sorry this a different computer and i forgot my yahoo password, I am responding to the person that wrote back to me. The basic thing i get so far is saying after i hit run "INSTALLER INTEGRITY FAILEDCONTACT AUTHOR FOR NEW COPY.". Another one I get is unable to verify or unable to verify security and the publshers are always showing up as unknown or security warning. The final result is that the file is corrupt. i hope this is enough info. I am not exactly what would be called computer literate.:confused:
As this is your first post in this forum, I do not know what you are referring to.
please provide the following info:
make, model and model number of pc
laptop or desktop
current antivirus
installed scanners
EXACT error message
More details
sorry about that, i originally posted this question under user HERKYDERK1,
My laptop is pretty dated by current standards but i dont require blazing speed. This is my first glitch since i got it.
System info:------------------
System Information
Time of this report: 4/11/2014, 11:04:02
Machine name: LATITUDED620
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130704-0421)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Latitude D620
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A10
Processor: Intel(R) Core(TM)2 CPU T5600 @ 1.83GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 817MB used, 3120MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
What happens is (hypothetically) I download a file , first box to pop up has the summary with Microsoft being the sender. it lets me save it, the next box says anyone of a few this, no digital signature so author cant be verified, or it says unknown publisher or installer integrity has failed, file is corruptif i am lucky enough to have publisher's still verified at this point i still get booted with this msg C\ "documentandsettings\user\mydocuments\downloads\apps_install_eng.exe is not a valid win32 application. Any one of these happen evry single time i try to download or install.
I hope this helps
This can be caused by anti-virus software. Also on Windows XP, this can sometimes be solved by temporarily disabling the windows firewall (or other firewall software.) This can also happen if a computer is infected with malware/viruses.
Here’s a list of troubleshooting steps:
  • Update anti-virus software, run full scan.
  • Run any other anti-malware softwares (we recommend MalwareBytes software.)
  • Clear browser cache.
  • Disable any installed download accelerator/managers.
  • Temporarily disable anti-virus software.
  • Temporarily disable windows firewall.
  • Disable other firewall software (such as nVidia firewall installed on some machines.)
  • Check hard drive integrity using checkdisk
if you do not have the recovery console installed:
run from the start menu
go to start, run, type in cmd
type exit and press enter
NOTE:
IE is now insecure, use firefox, chrome or another browser
One antivirus only and make sure that it is still supporting xp
On demand scanner for malware use Malwarebytes
