just installed a new power supply, even though it looks just like my original dell power supply, it has sata cables and moler cables, I have hooked up just the hard drive to the first moler 4pin connector from the power supply, I have not hooked up my dvd drive, (sata drive with an ide adaptor) as connecting the hard drive was the only way I could get my computer to boot up, comes up saying the secondary drive is not found, strike f1 or f2, so naturally I hit F1 as I knew that only the primary hard drive was connected.
there are two more moler connectors in line and the last has a little 4pin connector attached, I believe this was for the floppy that was originally installed, (dell dimension 3000 ).
So my question is how do I connect my secondary drive (it is a dvd drive), to the next connector in line?,
did not work when I tried this before, I could only get the dell splash screen, displaying F2 for setup and F12 for boot menu, but the keyboard would not work and the screen stayed there forever.
thanks in advance, I may be okay with software, but sometimes hardware throws me for a loop.
