Courtesy of Jose Ibarra
MAKE HIREN’S ON A FLASH STICK
You can also easily copy your personal data (documents, images, music) to an external drive.
From a working system, first download the latest version on Hiren's Boot CD from here (it is a substantial download but worth it):
http://www.hirensbootcd.org/download/ (look near the bottom of the page).
Unzip the Hiren's to some folder where you can find it. There is a Hiren's.BootCD.15.x.iso in there that you are going to need next.
Hiren's has instructions to make a bootable USB that you can use, but it requires you to first burn the .iso to a CD and some other steps, so I suggest another way and here's how:
Download RUFUS 1.4.x or whatever the latest version is from here (read some stuff on the page so you can know more about it):
http://rufus.akeo.ie/
Launch RUFUS and all the defaults should be okay, for the Device, choose your USB drive letter, Quick format, FAT32, label it if you want to and in the Format options box, click the little icon that looks like a CD and a window will open. Navigate that dialogue to point to the folder that contains the Hiren's.BootCD.15.x.iso that you unzipped earlier and the box should change to say ISO image (RUFUS understands the Hiren's ISO file).
Double check you have the right Device selected in the top
(NOT your HDD) Click Start, acknowledge the warning and let it finish (it will take a little while) as it copies the files. The Hiren's ISO is also good size.
You can also burn the iso to a cd with ImgBurn
http://www.imgburn.com/index.php?act=download
run the commands from either in a command prompt, I do not have linux but I believe that you can do this from linux also.
